37' Alwest Hull in SK. $8000
Another 37' striped hull
TO VIEW WHAT THIS VESSEL LOOKED LIKE AND ALL THE SPECS VISIT ALCANBOATS.COM ENTIRE HULL IS WELDED ALUMINUM WITH POLYURETHANE SPRAY FOAM INSULATION. THESE BOATS HAD WOOD SUPERSTRUCTURES. THIS ONE HAS HAD THE SUPERSTRUCTURE REMOVED AS WELL AS THE INTERIOR,RIGHT DOWN TO THE ALUMINUM HULL FRAMES.POWER IS TWIN 260 HORSE VOLVOS WITH 290 LEGS, CURRENTLY OUT OF THE HULL BUT GAURENTEED TO PERFORM PROPERLY. I CAN INSTALL FOR TWO THOUSAND DOLLARS . NO STEERING SYSTEM, ( ORIGINAL WAS TWO STATION HYDRAULIC. ) THIS HULL HAS SO MANY APPLICATIONS. WOULD MAKE AN INCREDIBLE LANDING CRAFT CAPABLE OF HAULING UP TO A ONE TON TRUCK . SELLING FOR THE ALUMINUM. 306-690-XXXX. I WOULD TAKE A TRACTOR ON TRADE. BILL
islanddiver
Re: 37' Alwest Hull in SK. $8000
Post by islanddiver »
Hello, I see you have a 37' Alcan hull for sale.
Is this boat hull still for sale?
Please advise
Thks, Wayne
Hi Wayne,
These ads are only examples taken from the Web, not the original ad. Use the link to go to the actual owner's ad to get info.
If the link is dead, then the boat has probably sold or is off the market. You could also try putting a part of the ad into Google to search for it on-line.
islanddiver
Hello, is this boat hull still for sale?
Please advise
islanddiver wrote:Hello, is this boat hull still for sale?
Please advise
See previous post.
