Slider Windows
bcarlson
Slider Windows
Post by bcarlson »
I want to remove the slider windows for track repair and servicing (clean and replace frabric). How do I remove the window?
Re: Slider Windows
If your windows do not have obvious attaching screws on the outside, the trim ring on the inside has to be removed and then the window frame is held only by the caulking. Carefully prying from the inside will free the window. See more info in the Alwest 370 superstructure restoration article in the tech section of the Alcan website. Replacement seals, glass run channels, etc are still available from the original manufacturer, Beclawat.
bcarlson
Re: Slider Windows
Post by bcarlson »
Perfect reply. Thank you. I will have to remove parts.
